Video from the owner...D16Y7 - Vitara Setup - 23.5 psi - 280 whp
Dr. D-Series
Come on Joe you have to give them the full effect of the setup http://www.honda-tech.com/zerothread?id=2270098
When Kareem showed me the video of the pulls you did on the highway i was very impressed PS this is Rayan Kareems friend lol. Props to Xenocron and Joe on the setup 10's this summer.
When Kareem showed me the video of the pulls you did on the highway i was very impressed PS this is Rayan Kareems friend lol. Props to Xenocron and Joe on the setup 10's this summer.H-tech
New numbers on this car, a year later and a lot has changed
Breakdown of setup. Z6 Motor 59300 w zex springs Vitaras and eagles Log manifold H1C w 18.5 cm hotside 2.25-2.5 inch charge pipes 38mm knock off wg 4 inch up-pipe 68-65mm TB and Ported Z6 intake mani from Chris Rc750's Head ported by me Ported and Shimmed oil pump by me Si trans w 7.5 lb flywheel and LSD clutch 24.5 psi on a 93/112 mix
Breakdown of setup. Z6 Motor 59300 w zex springs Vitaras and eagles Log manifold H1C w 18.5 cm hotside 2.25-2.5 inch charge pipes 38mm knock off wg 4 inch up-pipe 68-65mm TB and Ported Z6 intake mani from Chris Rc750's Head ported by me Ported and Shimmed oil pump by me Si trans w 7.5 lb flywheel and LSD clutch 24.5 psi on a 93/112 mixRegards, Xenocron Tuning Solutions eCtune Team eCtune Authorized Tuner Location: Ringwood, NJ / Hillburn, NY U.S.A. www.xenocron.com DIY ECU Chipping, Fuel Management Parts and more...
- g.t engineering
Yeah, he ran an 11.2 with 280...I cant wait to see what happens now at the trackg.t engineering wrote:that's a lot of power fr a single cam
Car is SICKKKKKKKKKK Went to the track today with Joe and he made three passes... 1st - 10.79 @ 130.5 mph (driving like a puss) 2nd - 10.61 @ 132.8 mph (had some issues on the launch) 3rd - 10.54 @ 131.9 mph Best 1/8\" of the day - 6.837 Best 60' of the day - 1.651 (stock axles, open diff!!) This is at a pretty shit track, car easily has 2-3 tenths in it as it sits now
Joe inspires people...its amazing how much attention this car gets at the track
- g.t engineering
