B20 killer vtec
kBS
B20 killer vtec
Post by kBS »
B20 w/ killer vtec P&P Head / stock valve size 13:1 CR Performer X intake 68mm TB / Tri Y header 252 whp@9100 rpm, runs fine up to 10000 rpm :D , didn`t tested when the power decreases, on dynojet should be like 265 whp, I thinks is not bad for that stinky intake :x
Post by thething96 »
When you say\"killer vtec\", are you refering to really good vtec, or is it more like \"vtec killer\", as in non-vtec>VTEC???
I think he's got Toda Killer cams. Great result!
VERY NIICCEEEEEEE!
Hatch h22 all-motor
Post by Hatch h22 all-motor »
Nice are you going to post the graphs?
h22 stock N/A
kBS
Post by kBS »
Hatch h22 all-motor wrote:Nice are you going to post the graphs?
You mean the log?? And yes the engine has Toda Killer Vtec cams, very very nice cams :D
Muy buena potensia!!
kBS
Post by kBS »
thething96 wrote:Muy buena potensia!!
se agradece gracias, hoy marco 8.5 scnd 1/8 mille spining all the way :evil:
hpmx18
Post by hpmx18 »
im doin a similar setup the same c/r atlease would u mind posting the file or the basemap you used
9400RPMS
Post by 9400RPMS »
mind sharing the map? Whats the injectors? same setup as me, expect i'm not running vteckillers i'll be going with a set of m24x's and i have a victorX i'd like to take a look at your map tho.
DDTech | DDTECHCAMS.COM
kBS
Post by kBS »
I´m sorry, I got my tuning laptop stolen and also my external hard drive with all the backups :cry: Will try to contact the customer and read the ecu
Open header or has it some kind of exhaust behind it? btw, what type of Killer cams do you have? I thought there were 3 types of killer cams?
kBS
Post by kBS »
Gaskleppie wrote:Open header or has it some kind of exhaust behind it? btw, what type of Killer cams do you have? I thought there were 3 types of killer cams?
Exhaust to the door on 2`` or 2,5`` I don´t remember certainly. There are many types of killer, this case was made by Toda Racing stg3
92bluepreludesi
Post by 92bluepreludesi »
would love to see a video of how your car sounds!
