Big port B18A1  DSM 450cc  Vickie-X IM  CC-Fab topmount  A number 1 top quality SSAC turbo
    I spent most the day fighting ignition misfires/phantom revlimits; the car was a victim of a poorly done wiring tuck, Brandon had to replace the engine harness and undo all the masking tape/twist tie wiring under the fuse box to get the car this far.     5 psi creeping to 7.5 the last 1000 rpms:
      8 psi creeping to 9 psi the last 1000 rpms:
      I have to say I'm fairly impressed, and had no idea a big plenum IM and topmount manifold would support that sort of flow through a stock cam LS.  I would have pushed closer to 300, but the car apparently has a stock clutch.  Er,
had I stock clutch, I mean.
									Regards,   Joseph Davis  eCtune Team   eCtune Authorized Tuner   Location: Asheville, NC  USA
