B18C 231whp
MikeySpec
B18C 231whp
Post by MikeySpec »
Image The bottom end consists of 100% oem parts. Runs on pump gas and is driven daily. PortFlow B16 Head Jun3 Cams w/ gears Edelbrock Perf. X Manifold Hytech Rep. Big Tube Omnipower Valvetrain Simple, Basic, and Cheap. Track results(1/4 mile) will be up possibly tonight. Here is a comparison of this engine vs. a K20r w/ RBC and bolt ons. Image The K20 makes 218.5 whp.
shogun
Re: B18C 231whp
Post by shogun »
MikeySpec wrote:Image The bottom end consists of 100% oem parts. Runs on pump gas and is driven daily. PortFlow B16 Head Jun3 Cams w/ gears Edelbrock Perf. X Manifold Hytech Rep. Big Tube Omnipower Valvetrain Simple, Basic, and Cheap. Track results(1/4 mile) will be up possibly tonight. Here is a comparison of this engine vs. a K20r w/ RBC and bolt ons. Image The K20 makes 218.5 whp.
Very good numbers. The only problem is the pic is not available any more. Your b18c has really any cr increasement? your pistons are stocks? Very impressive to obtain so good values with so few mods.
mik
Post by mik »
What did you end up setting your cam gears at? Just curious. Wish the pics still worked. Good job!
julien
Post by julien »
What kind of air intake do you have ? Do you have a map drop from . Thank's
Yippee-ki-yay, motherfucker!
JDMirza
Post by JDMirza »
Try reposting the pictures if you can, curious about the cam gear setup as well. Really well done with those kind of mods!
