86 Honda Accord
86 Honda Accord
My 86 accord used to be carbureted. I converted it to Fuel injection and then to OBD1. I turboed it about a year and a half ago. I've been running 8psi until I had it tuned recently I turned the boost up to 12psi using the ectune ebc. While on the dyno i figured out the turbo was too small for the motor since it won't hold full boost to reline it drops from 12 to 7psi at redline. I had to run maps from a b18, p75 ecu, since there are none specifically for my motor. Stock Motor(A20) w/151k arp head studs torqed down a little extra Gude cam Golden Eagle cam gear advanced 1 deg. T3 42/48 It made 239whp and 237wtq. Run one was on 8psi, run two on 12psi. Here's a few pics of the car. Its not pretty but its fun to drive.
OBD1 Turbo 86 Accord
- integralactic
- 4thgenhtch
I've never weighed it, but the weigh from the back of the owners manual is 2500lbs. Its probably around there with all the stock parts removed and modifications added. I ran a 9.113 @ 79.79 mph witha 2.184 60ft in the 1/8th mile. The motor is currently being built and a larger turbo is going on (sc60).dbsharp wrote:Very nice. How much does that car weigh?
