Stock B16 - 327whp @ 14psi
ultra spikey
Post by ultra spikey »
Finally got around to tuning my car. Put down 327whp at 14psi. Stock block B16, aebs intake manifold, revhard exhaust manifold, 57trim 63ar t3to4e, 3\" downpipe/exhaust. My goal was 320whp so i'm happy about the result. I am kind of dissapointed about the spool time. It seems really laggy. I dont hit 14psi till about 5600rpm. Image Image Image
323_24092008_1745.elf
3rd gear log
(101.88 KiB) Downloaded 532 times
nice, did you find what caused the pop through the exhaust??
Regards, eCtune Team eCtune Authorized Tuner Location: Port St Lucie, Fl,
EITCP
Post by EITCP »
good numbers. I am making same setup like you for one customer's car and i would like to know how laggy this turbo is. When do you get 4psi of boost, at what rpm?
Very clean car 8)
ultra spikey
sewell94 - I think it may have been from not enough timing. As I started bumping up the timing, it went away. I also changed the gap from .026 to .024, so that may have helped also. EITCP - If I could switch turbos right now, i'd do it in a heartbeat. Not really fun to drive with this much lag. I'm thinking it may just be the turbo, because i've seen b16's with the same turbo spool up faster. I'm at work now so I couldnt tell you when I hit 4psi, take a look at the datalog.
zex_cool
Post by zex_cool »
thats a normal spool time with the b16/57trim combo. nice numbers!!
Nice numbers ! Good looking ride you got there as well.
ultra spikey wrote: I'm at work now so I couldnt tell you when I hit 4psi, take a look at the datalog.
Please post .cal then. Log's use .cal file for right numbers...
boostedeh2
Post by boostedeh2 »
Garrett
Post by Garrett »
that's great pump gas?
ultra spikey
Garrett wrote:that's great pump gas?
yea
Garrett
Post by Garrett »
very nice
b20beast
Post by b20beast »
please post cal so we can see datalog
