Page 1 of 2
				926HP 562tq Curtis Green Coupe Tuned by RSTECH
				Posted: Sun Oct 26, 2008 10:38 pm
				by rschoener
				Curtis SFWD Green Coupe    926HP 562TQ 36PSI Boost    GSR Block, LS Crank, Bart built
   CP Pistons 84.5 Bore 9:1 compression  Manley Turbo Tuff Rods (LS)  Skunk 2 Pro 1 Cams  Manley Springs and Retainers  Manley Valves  Head (??????)  Aeromotive Eliminator Fuel Pump  -8an fuel line up and back   Sump in stock tank  Aeromotive Fuel Regulator  3� intercooler piping  Precision Intercooler  GT42r 94 (1.15 ar) turbo  Eddlebrock Intake  Eddlebrock 70mm throttle body  1600cc injectors (KG Parts) W/ Resistor box  Stock Distributor  Igniter replacement (PGMFI.org)
   MSD Digital 6  MSD Coil (I forget the model. But it’s the big blue one for the digital 6)  NGK Plug Wires  #9 heat range plugs  MFactory Gear Set  eCtune W/ PWM Boost Control  VP Q16 Fuel  Tuned by RSTECH  Land and Sea Dyno    We are going to try and get to the track this Tuesday. Hopefully we can get some traction and put down some good track numbers.
				Posted: Sun Oct 26, 2008 10:56 pm
				Bad ass!   I've been trying to find a customer thats willing to shoot for 1000HP on Q16.. From what this setup is doing do you think the fuel is stable enough to make 1000+  ??
				Posted: Mon Oct 27, 2008 2:09 am
				good stuff!!!!!!!!!!!!!!!!!!!!
				Posted: Mon Oct 27, 2008 2:24 am
				by sewell94
				DAMN!!!
				Posted: Mon Oct 27, 2008 3:31 am
				by integralactic
				wow mean!!
				Posted: Mon Oct 27, 2008 12:54 pm
				by nate
     rock on
				Posted: Mon Oct 27, 2008 1:20 pm
				by fah
				Awesome ... thumbs up
				Posted: Mon Oct 27, 2008 3:02 pm
				by rschoener
				Bugermass wrote:Bad ass!   I've been trying to find a customer thats willing to shoot for 1000HP on Q16.. From what this setup is doing do you think the fuel is stable enough to make 1000+  ??
    Chris,  I'm unsure. I use VP import on our race car and I think I have a lot more safty with that fuel. I choose VP import on our car since my plan is be aound 1000+ by next season. . I like the Q16, I went though many sets of plugs doing this car. for my own sanity...
 the burn seems to leave a lighter / slightly greenish color at the same A/F as C16. The car pulls rock solid up top and we will probbly push it some more but later after we get some good track numbers. I will have to post up some pics of the plugs. I would like some opinions on them from people who have used this fuel. I think we could get up to that number with the Q16. I may try it in our car at some point also.
				Posted: Tue Oct 28, 2008 2:53 pm
				by ge0ne
				Give me some info on the Mfactory gears, are you using the pro ones? do they withstand the power? Are you satisfied with them?
				Posted: Tue Oct 28, 2008 6:07 pm
				by xenocron
				Have fun going to the track (in the snow)
    Awesome stuff Randy.
				Posted: Wed Oct 29, 2008 12:40 am
				Cool, yea I'd like to see your plugs when you get a chance to post them.. Actually if you don't mind posting the cal too that would be cool, if not I understand, I won't hold it against ya
				Posted: Wed Oct 29, 2008 10:57 am
				by sohcd16y8
				Thats just awesome.
				Posted: Wed Oct 29, 2008 1:18 pm
				by rschoener
				Bugermass wrote:Cool, yea I'd like to see your plugs when you get a chance to post them.. Actually if you don't mind posting the cal too that would be cool, if not I understand, I won't hold it against ya
    No track runs yet. Rain.....  I will post the Cal and some datalogs from dyno tonight. also pic of plugs. I have no problem posting up the cal. I think that if someone had the exact same setup It would great to help them out. also it good for me to get feedback. I am always learning.
				Posted: Mon Nov 17, 2008 11:05 pm
				by Mr T
				Awesome Results . Which land Sea dyno do you have ? We have one as well ?
				Posted: Sun Jan 25, 2009 3:08 pm
				by ACTION JACTION
				Niceeee!!!  I think everyone would like to know how does eCtune idle those 1600cc with the resistor box and not even an injector driver?  The MSD coil you are referring to is the HVC 2.
