B16A T3/T4 6PSI 203WHP 139TRQ
stock pistons can hold a lot with a good tune. i tuned several B16 cars with turbo and 9-10 psi and they still driving around. ieven tuned stock JDM ITR B18c6 turbo at 7psi and the engine still holds together. if stock pistons can not handle this boost then sooner or later forged ones will give up too because it is a tuning problem. B20beast must take off the head and see what realy happened.either he cracked ringlands (timing probem)or damaged piston skirts/sleeve bores (wrong fuel map).
- ge0ne
i am talkin of not safe and less hp. But accurate, more hp and more closer to the big bang. Either way it always depends on the way you drive. Hitting ALWAYS 8-9k rpm continuously on stock internals will get you closer to the end. I don't believe that ring lands broke from pressure or tune, but maybe both. The pressures i gave are on the safe side for everyday abuse!
But everyone said the timing maps look good and the arf was in the 11.5-12.5AFR Rangege0ne wrote:i am talkin of not safe and less hp. But accurate, more hp and more closer to the big bang. Either way it always depends on the way you drive. Hitting ALWAYS 8-9k rpm continuously on stock internals will get you closer to the end. I don't believe that ring lands broke from pressure or tune, but maybe both. The pressures i gave are on the safe side for everyday abuse!
- ge0ne
100 ect, is not a big issue, of course it can help the damage but probably it went that high a little after the damege or a little before, an aluminum radiator is a must, and i always use a low temp thermostat and a thermo fan switch on setups like this. Gaskleppie i couldn't agree more with you.
Thanks, i got a Aluminum Radiator i will try a low temp thermo... also why is there a need for a thermo fan switch, ectune can control the fan to turn on earlierge0ne wrote:100 ect, is not a big issue, of course it can help the damage but probably it went that high a little after the damege or a little before, an aluminum radiator is a must, and i always use a low temp thermostat and a thermo fan switch on setups like this. Gaskleppie i couldn't agree more with you.
I've made over 400 on stock pistons/rods and pump gas and over 500 on stock pistons/rods on race gas.. The pistons arn't the problem.. You said you put a 10 PSI spring and the map sensor only read 8. If your using a stock map sensor this somtimes happens. Even though they are supposed to read like 11 PSI, I've had some stock honda maps sensors only read like 7 psi and actually be at 12.. The stock sensors are not very consistant and you have to pay very close attention to actuall boost externally from the ECU when using them.
ahhh this makes alot of sense. i have a mechanical boost gauge/autometer. it didn't go up near the 10psi mark at all. but lets say it read 12psi, the ecu referenced the 6-8psi column would it matter because its reading from there? but my green spring read correct..... 6.5psiBugermass wrote:I've made over 400 on stock pistons/rods and pump gas and over 500 on stock pistons/rods on race gas.. The pistons arn't the problem.. You said you put a 10 PSI spring and the map sensor only read 8. If your using a stock map sensor this somtimes happens. Even though they are supposed to read like 11 PSI, I've had some stock honda maps sensors only read like 7 psi and actually be at 12.. The stock sensors are not very consistant and you have to pay very close attention to actuall boost externally from the ECU when using them.
The stock thermo fan switch is a 93°C one so you can't control the fan earlier if you want to go lower you need a new (mugen style) thermo fan switch regardsb20beast wrote: Thanks, i got a Aluminum Radiator i will try a low temp thermo... also why is there a need for a thermo fan switch, ectune can control the fan to turn on earlier
Basically what will happen is your making 12 PSI of boost, but the ECU only thinks your at 6 or 8 or whatever so you end up with only enough fuel for 8PSI and a bit too much timing.. Also we have like 3-4 different boost guages floating around the shop and they are all off from each other. Anyone whos tuning a boosted car should really do themselves a favor a buy a really nice quality liquid filled mechanical boost guage. Its almost as important as a good wideband.. pressure sensors vary and its always good to know EXACTLY how much boost you are really running, especially if you don't have a dyno at your disposal to find MBT..b20beast wrote: ahhh this makes alot of sense. i have a mechanical boost gauge/autometer. it didn't go up near the 10psi mark at all. but lets say it read 12psi, the ecu referenced the 6-8psi column would it matter because its reading from there? but my green spring read correct..... 6.5psi
ok another question lets say the ecu read 8psi but actually at 12psi.... wideband shows a consistaant 11.5-12.5AFR. So i assume i was in the right column. What do you make Also what brand makes mechanical liquid filled boost gauge?Bugermass wrote:Basically what will happen is your making 12 PSI of boost, but the ECU only thinks your at 6 or 8 or whatever so you end up with only enough fuel for 8PSI and a bit too much timing.. Also we have like 3-4 different boost guages floating around the shop and they are all off from each other. Anyone whos tuning a boosted car should really do themselves a favor a buy a really nice quality liquid filled mechanical boost guage. Its almost as important as a good wideband.. pressure sensors vary and its always good to know EXACTLY how much boost you are really running, especially if you don't have a dyno at your disposal to find MBT..b20beast wrote: ahhh this makes alot of sense. i have a mechanical boost gauge/autometer. it didn't go up near the 10psi mark at all. but lets say it read 12psi, the ecu referenced the 6-8psi column would it matter because its reading from there? but my green spring read correct..... 6.5psi
