Page 1 of 2
My B16 turbo semi-build
Posted: Sun Jul 05, 2009 7:25 am
by Civic VTI-Turbo
81,5mm Wiseco 9:0 pistons Eagle rods GSR cams Type-r intake 1000cc precission Walbro 255lph 70mm TB 2,5 ic piping Xs power intercooler APE Ramhorn Xs power t04e .63/.50 ar 38mm screamerpipe APE 3inch downpipe Greddy SP2 2,5inch catback EBC set @ 15 psi Pump gas! Ron 98 IAT temps(50+ Celcius) were very high! Because it was very hot inside.... Never the less, i made 347,3 Bhp with a quick tune.... Image Image Image Image
Posted: Mon Jul 06, 2009 3:36 pm
by b20beast
looks really good
Posted: Mon Jul 06, 2009 3:39 pm
by b20beast
You didnt mention what turbo
Posted: Mon Jul 06, 2009 7:03 pm
by Civic VTI-Turbo
b20beast wrote:You didnt mention what turbo
Oh! My bad... It's a t04e xspower :oops: I maby want a other turbo, but don't know what will be the right choice. But first i want to max out this setup!
Posted: Fri Aug 28, 2009 7:59 pm
is it sleeved ?
Posted: Sat Aug 29, 2009 12:49 am
I wouldn't recomend trying to max out that setup with that turbo.. You have a really nice setup it'd be a shame if you tore up your motor due to a ebay turbo compressor wheel desinegrating and going into your motor.. Get a good turbo, then crank that shit up!!!
Posted: Mon Aug 31, 2009 12:30 pm
by Civic VTI-Turbo
Bugermass wrote:I wouldn't recomend trying to max out that setup with that turbo.. You have a really nice setup it'd be a shame if you tore up your motor due to a ebay turbo compressor wheel desinegrating and going into your motor.. Get a good turbo, then crank that shit up!!!
Yes, i've recently tried to upgrade the boost. But only 18,59 psi came out! And the EBC is set 100% fixed duty cycle... :shock: (strange?!) I'm looking for a real Garret T04e. So if anybody has 1, please do PM me. @ [email protected] No, stock sleeves.... I'm also having some problems with the engine. I've checked the compression etc.. everything is in good order! But he is spitting out all of his oil into the catchtank( at high rpms). Is this normal?! Edit, i'm using these plugs from B&R. Image
Posted: Tue Sep 01, 2009 6:00 am
by Sowler
Remove that breather thats to the left of your oil filter that will be your problem. Preferably block them both back up and run two breathers from the front of the rocker cover.
Posted: Tue Sep 01, 2009 10:38 am
by fah
Sowler wrote:Remove that breather thats to the left of your oil filter that will be your problem. Preferably block them both back up and run two breathers from the front of the rocker cover.
nope he does not have to put them both back. My ENDYN breather kit came with the same two breathers which lead to the side of the can. There was a port in the bottom of the can which lead back to one of the two lines. Thus one of the lines was a "Y" allowing the oil to drain back into the engine. I ran my car like this for almost two years with no problems. If you do this and you are still breathing oil, then maybe you are getting blow-by or cracked a piston
Posted: Tue Sep 01, 2009 3:17 pm
by Civic VTI-Turbo
That is something i want to try. I've just bought myself a Garret T3/T04e 60trim :)
Posted: Sun Sep 13, 2009 3:42 pm
by ed7_vti
Civic VTI-Turbo wrote:Yes, i've recently tried to upgrade the boost. But only 18,59 psi came out! And the EBC is set 100% fixed duty cycle... :shock: (strange?!)
which spring you are using in the wastegate ? which boost you are running with EBC off ?
Posted: Sun Sep 13, 2009 3:53 pm
by ckretvix
Lovin the car
Posted: Mon Sep 14, 2009 1:36 am
by Civic VTI-Turbo
8,7 psi spring, was thinking of using a 13,5 psi spring.
Posted: Thu Sep 17, 2009 9:28 pm
by FreshDA9
nice looking car, and good numbers.
My B16 turbo semi build
Posted: Wed Nov 11, 2009 8:51 am
by DyeceDic73
There are a few NA VX220s in the system but no Turbo ones. Perhaps someone like Thorney Motorsport can oblige and upload one for us as theyve surely done one.
