b20vtec TWM ITBs with and w/o filters
EITCP
Post by EITCP »
Ok...... Pretty nasty difference! What are the engine spec's?
EITCP
Post by EITCP »
85x89mm endyn pistons 12.6:1 comp crower rods aebs sleeves TWM 52mm ITBS RC440 rage small tube header 2.5\" exhaust skunk pro2cams
marshall.hagen
Post by marshall.hagen »
What type of filter element? ITG?
EITCP
Post by EITCP »
this design; http://i38.tinypic.com/168y6pt.jpg this dyno comparisation was made because the customer complaints about high fuel consumption and low power on a butt dyno. I must say i have tuned this setup w/o filters so the next day he put them himself and called me after a week. I discovered the AFR went from 13:1 (tuned by me) to 11:1 on high revs full throttle :shock:
marshall.hagen
If he still wants to run a filter element, the ITG full frame filters meant for ITB's work great. Or he can fabricate a plenum/airbox and run a pipe (like a cold-air-intake) to a cone filter. Thank you for posting the results.
9400RPMS
Post by 9400RPMS »
what were the gear settings and mind sharing the map?
DDTech | DDTECHCAMS.COM
