however I had major issues with ectune.   1. My 1000cc Precision injectors were maxxed out according to ectune. It was 97% at 425whp.  2. For some reason my boost silenoid settings were changing from open to closed. I tried to save it closed but when I would reopen my map it would change to open.    If anybody could help me with those 2 issues I think I would feel comfortable making more power and I'll feel better about ectune.425whp lsvtec turbo
				92redhatch
425whp lsvtec turbo
    however I had major issues with ectune.   1. My 1000cc Precision injectors were maxxed out according to ectune. It was 97% at 425whp.  2. For some reason my boost silenoid settings were changing from open to closed. I tried to save it closed but when I would reopen my map it would change to open.    If anybody could help me with those 2 issues I think I would feel comfortable making more power and I'll feel better about ectune.- Gaskleppie
				92redhatch
- IHaveTurbos
 - <font color=red>eCtune Authorized Dealer</font><br><font color=green>eCtune Authorized Tuner</font>
I don't always watch and see what the program says the duty cycle is at as it can be off. You have to watch the A/F ratio and make sure you are still good.    Now if your A/F was dropping and your only making 425whp with Precision 1000cc at a base pressure of 60psi then you have a issue in your fuel system. If not then don't worry what the program is saying and keep tuning to you truly run out of injector or pump.    My car on eCtune says I'm at 100% injector at around 400whp with the ID1000's on a 65psi base but I still had plenty of injector and didn't run out of pump and injector until 677whp, but I'm also using E85 and twin walbros.
									Tim - Owner of Turbo Elements  www.turboelements.com    Dynocom DC-1800sz-SE
				92redhatch
There is a math formula you can use to calculate actual duty cycle as well, injector time vs rpm I believe.     Last season w an oem regulator I was showing maxed out @ 28psi, s366, id1000s. Did the math, it was correct. added a 1:1 fpr using a higher base, dropped injector duty down 30% or so, not a problem since.
									DKGoodrich  EFI Tuning Solutions  eCtune Authorized Tuner  Frankfort, KY, U.S.A.   859-421-3334  http://www.dkgoodrich.com
