Page 1 of 2
243WHP 8:1Cr B16a
Posted: Mon Mar 15, 2010 1:15 pm
by b20beast
Posted: Mon Mar 15, 2010 2:28 pm
by Civic VTI-Turbo
How is the boost? Is it stable?
Posted: Mon Mar 15, 2010 3:33 pm
by b20beast
Civic VTI-Turbo wrote:How is the boost? Is it stable?
i attached a pic with the boost log...
Posted: Tue Mar 16, 2010 1:44 pm
by EITCP
what kind of turbo manifold you have?
Posted: Tue Mar 16, 2010 4:27 pm
by b20beast
EITCP wrote:what kind of turbo manifold you have?
Its a cast manifold.... like a ugr cast racing manifold
only mine isnt jet coated
Posted: Wed Mar 17, 2010 12:10 am
send me your map I'll make changes and send it back..
Posted: Wed Mar 17, 2010 12:11 am
or post it here..
Posted: Wed Mar 17, 2010 8:19 am
by b20beast
Thanks buggermass!
Posted: Wed Mar 17, 2010 7:57 pm
I'll dl and clean it up a little tommorrow.. Do me a favor and do a 3rd and or 4th gear pull if you can on a fresh set of plugs then take a pic and post it.. I need to see the ground strap.
Posted: Wed Mar 17, 2010 8:19 pm
by b20beast
Bugermass wrote:I'll dl and clean it up a little tommorrow.. Do me a favor and do a 3rd and or 4th gear pull if you can on a fresh set of plugs then take a pic and post it.. I need to see the ground strap.
what are we looking for? DET or AFR?
Posted: Wed Mar 17, 2010 11:37 pm
timing reference.
Posted: Thu Mar 18, 2010 3:34 pm
by b20beast
Bugermass wrote:timing reference.
Do you think theres a flow restriction? boost leak or smtn?
Posted: Thu Mar 18, 2010 11:22 pm
try this.. Keep an eye on your fueling I made some small changes. it should feel wayy smoother, but I'm pretty sure this is still conservative for the compression your running. also.. be SURE your timing is synced properly. lemme know how it goes. if you throw in a new set of plugs and do a couple runs then pull them and take pics I can help you get this thing dialed in.
Posted: Fri Mar 19, 2010 2:58 am
You give free tuning over the Internet now??? >XD
Posted: Fri Mar 19, 2010 3:49 pm
by Civic VTI-Turbo
Timing looks much better now Burgermass....
