Page 1 of 2
505HP 356TQ Stock Bottom LS
Posted: Fri Nov 19, 2010 2:08 am
Well so it was time to break another record for stock block LS. Stock bottom end, ported head with our regrind cams, 20G with ebay tubular manifold @21 PSI on Q16.
Posted: Fri Nov 19, 2010 2:09 am
wish is had rods bolts so I could have revved it higher
Posted: Fri Nov 19, 2010 2:44 am
Posted: Fri Nov 19, 2010 4:49 am
by Vtec6000
Nice
Should be fun to drive
check your pm's Chris
Posted: Fri Nov 19, 2010 7:40 am
I have a set of D-series ARP bolts... not sure if they are the same....
Posted: Fri Nov 19, 2010 7:45 am
by BillB
Impressive
What boost is that at? In a CRX that would be awesome! Y49 as well mmmm
When you say 20g is that an upgraded version of a Subaru/Mitsubishi 16g? I have a 10.5mm Evo6 16g with a tigart manifold going on my B18c & I've been looking at the 20g cold side upgrade they list it rated to 450hp on a Evo... Bill
Posted: Tue Nov 23, 2010 4:46 am
by TopMountGSR
Damn, I didn't know a 20g could make that kind of power on these cars! Good Job Chris!
Posted: Tue Nov 23, 2010 9:50 pm
by 9400RPMS
Serious....serious...power .. go BUGERMASS!!!
Posted: Thu Nov 25, 2010 3:13 pm
Its mainly the cams that make it possible. The original shop that I worked for back in like 1999-2000, went through about 4 revisions of the these cams before we found a profile that we loved. Back then it was for all motor, but one day I decided to throw them in a boosted motor and i was like holy hell!!.. They are just plain a great all around cam for an LS. I'm thinking of having crower or webb or somone make them on a production level for us. They have tons of lift, tons of duration, but the actual profile is very gentle on the valvetrain, I've run these to 8K on stock springs and retainers with no issues, and on a built head will make power to 9200-9400 or so without poping out rockers.
Posted: Thu Dec 02, 2010 1:23 am
by ckretvix
How are they in comparison to say the 404s?
Posted: Thu Dec 02, 2010 11:01 pm
not to be mean, but 404s are garbage .. Yes ppl make power on them , but they are really crappy compared to these and make significantly less power than my regrinds. I can run my regrinds on stock spring and retainers to about 7800RPM safely. and they have way more lift and duration than 404s.. They just have a much gentler ramp in/out .. Designed by a real cam engineer. lol.
Posted: Sun Dec 05, 2010 4:17 am
by FreshDA9
Wow very impressive numbers on a stock LS.
Posted: Sun Dec 05, 2010 2:51 pm
by 9400RPMS
Bugermass wrote:not to be mean, but 404s are garbage .. Yes ppl make power on them , but they are really crappy compared to these and make significantly less power than my regrinds. I can run my regrinds on stock spring and retainers to about 7800RPM safely. and they have way more lift and duration than 404s.. They just have a much gentler ramp in/out .. Designed by a real cam engineer. lol.
Mind sharing your cam engineer?? If not, i understand but Myself, rocket and donf do use the same grinder, and he is very well known, i love this, i've spread this link to a few forums just to show what ectune can do.. Again, Great buger.. looks euper nice.
Posted: Sun Dec 05, 2010 4:55 pm
I use Clay Smith to grind my cams.
Posted: Fri Dec 10, 2010 9:28 am
by ckretvix
Bugermass wrote:I use Clay Smith to grind my cams.
Do these idle better then 404s?
