3rd gear street pull
92redhatch
Post by 92redhatch »
92redhatch
YouTube - ‪500whp civic on the street‬‏ 2nd and 3rd gear Had someone actually record it for me. 522whp
9400RPMS
Post by 9400RPMS »
Sounds outstanding..really does.
DDTech | DDTECHCAMS.COM
92redhatch
Thanks I really don't drive the car on the street that often. I've been neglecting the car so I needed to have some fun with it to gain interest.
Needs a tire and/or boost dialed in ;) Sounds good!
92redhatch
Btw that's with fast spool at 0. Wastegate activation 0 and ebc activation at 0. So it could come in sooner.
92redhatch wrote:Btw that's with fast spool at 0. Wastegate activation 0 and ebc activation at 0. So it could come in sooner.
I set: Fastspool to 100% EBC activation = 1000mbar, or 0psi Wastegate activation = [WG spring pressure x 0.66] You should consider, m&h street & strip. I have ran just about every manufacture drag radial available and none comes close to the hooking ability of a m&h street and strip. They are amazing tires to say the least. I hooked almost 500whp in second gear on the street. It was a beast from a 45 roll.. ;)
92redhatch
Any reason why you set ebc activation at 0?
