This is kind of a sad post, customer got 30-40 miles on the car and did the good old fashioned 1-2-3-2 shift, now exhaust valves on cyls 2 and 3 don't close. Hopefully it just needs valves/guides replaced. Stock sleeve LS/VTEC block with pistons/rods RC750cc injectors Spoolin Performance mini-ram and downpipe T3/T04E 93 octane 10 psi wastegate: 13-14 psi: 19 psi:
only revving to 7800? interesting at 13-14 psi you were only gaining ~10 hp per psi...but at the 19 psi level you gained over 11-12 per psi and it also doesnt look like you were hitting full boost in any of the graphs until after 6 (about the same no matter the boost level)
