244whp and 170wtq B18 w TWM ITBs tuned on eCtune
neoh2ning
Post by neoh2ning »
First of all THANK YOU CALVIN this thing ROCKS. Got the thing runnig on a couple of minutes the datalogging helped a lot did a little street tuning and to the dyno. Got 244 and 170 the setup: GE sleeved 86mm B18 Alaniz head hytech header skunk2 cams TWM ITBs 52mm Stock crank as soon as i get a break i will post the graph thank you. NeOh2ning from PUERTO RICO.
ultra spikey
Post by ultra spikey »
wow...whats the compression?
neoh2ning
Post by neoh2ning »
custom CP pistons 86mm around 12.2:1 runs were made on 93 octane pump gas down here and we used the stock headgasket opened to 86mm
