I just got done with this car today.  Overall, I'm very impressed.    Run 18 = ~18-19psi, 438hp / 284 tq  Run 8 = ~12psi, 347hp / 234 tq  Run 4 = ~10.5 psi, 334hp / 223 tq    Car was a ~9:1 1.8L vtec motor (Sleeved ITR bottom / B16 head, GSR cams) and a GT35e non-ball bearing turbo run on 93 octane with 1000cc Precision injectors.      We had significant issues with misfiring/blowing out spark at higher RPMs.  Being able to mess with dwell settings for the coil in eCtune really helped a lot towards getting the misfires taken care of.  Literally, all I changed in the last run was the dwell table in order to clean up the dyno to the point where it could go home.  I guess we'll see if there is a detrimental effect on coil life...  It sure as hell helped spark strength.  R5671-8 @ 0.020-0.021\"    Individual cylinder trim for both fuel and spark was really helpful too - saw marked changes.  Hard to tell if it was a result of the 10% fuel in #3 or the -1 degree spark, but it ran super clean.  Pretty neat.    Ignition adjustments being off were very handy too.  I'm not sweating this one having issues.  Yay!    The motor could definately have made more power with more boost and more revs, but it was already having issues blowing out the spark BAD and the owner didn't want to push it any harder on pump gas.1.8L vtec motor - 438whp 93 octane
				blundar
  I just got done with this car today.  Overall, I'm very impressed.    Run 18 = ~18-19psi, 438hp / 284 tq  Run 8 = ~12psi, 347hp / 234 tq  Run 4 = ~10.5 psi, 334hp / 223 tq    Car was a ~9:1 1.8L vtec motor (Sleeved ITR bottom / B16 head, GSR cams) and a GT35e non-ball bearing turbo run on 93 octane with 1000cc Precision injectors.      We had significant issues with misfiring/blowing out spark at higher RPMs.  Being able to mess with dwell settings for the coil in eCtune really helped a lot towards getting the misfires taken care of.  Literally, all I changed in the last run was the dwell table in order to clean up the dyno to the point where it could go home.  I guess we'll see if there is a detrimental effect on coil life...  It sure as hell helped spark strength.  R5671-8 @ 0.020-0.021\"    Individual cylinder trim for both fuel and spark was really helpful too - saw marked changes.  Hard to tell if it was a result of the 10% fuel in #3 or the -1 degree spark, but it ran super clean.  Pretty neat.    Ignition adjustments being off were very handy too.  I'm not sweating this one having issues.  Yay!    The motor could definately have made more power with more boost and more revs, but it was already having issues blowing out the spark BAD and the owner didn't want to push it any harder on pump gas.eCtune Team  eCtune Authorized Tuner  Location: Cincinnati, Ohio, USA  \"That motor's hit!\" - me
Nice, so you took out or added dwell to help the spark blowing out?    Nice numbers...since when did you start using a Dynojet?
									Regards,  Xenocron Tuning Solutions  eCtune Team  eCtune Authorized Tuner  Location: Ringwood, NJ / Hillburn, NY  U.S.A.    www.xenocron.com    DIY ECU Chipping, Fuel Management Parts and more...
- Synoptic
what was the AF reading when you were having missfire?
									Synoptic Tuning  Regards,  eCtune Team   eCtune Authorized Tuner  Location: Montreal, Quebec, Canada
				Mind-Eracer
				TurboGoKart
Yeah Scott its my car.  It runs great!    Setup:    Sleeved C5 block 81mm  9.0:1 CP  Manley Rods  B16 head   Supertech springs and retainers  blah blah ect....    Precision GT35E  1000cc inj.    The car:
    The goodies:
    The Dyno:
      Im looking forward to getting the logger version of the software so I can datalog at the track ect...  and we will be setting up the boost control as well.  The car wont hook at all on the street at the current boost level 18psi until 4th gear.
    The goodies:
    The Dyno:
      Im looking forward to getting the logger version of the software so I can datalog at the track ect...  and we will be setting up the boost control as well.  The car wont hook at all on the street at the current boost level 18psi until 4th gear.-
				TurboGoKart
