Which wideband for permanent install?
				Vtec6000
What wideband gauge kit would you guys recommend for a permanent install in car?
				pandorasbox
I have heard tons of praise about PLX, in fact my buddy who tunes for a living used a PLX everyday on a lot of cars with great success.     I have an LC1 and it's alright, installation and stuff was kinda a pain and the calibration LED never lights up (probably DOA) but so far it's been very accurate and fast.     I have also used the AEM EUGO and it's a breeze to install, and pretty accurate.     I've had others say Tech Edge WBs are awesome too.     Hope this helped.
The AEM Eugo was actually the one I was considering, the gauge looks pretty nice when installedpandorasbox wrote:I have heard tons of praise about PLX, in fact my buddy who tunes for a living used a PLX everyday on a lot of cars with great success. I have an LC1 and it's alright, installation and stuff was kinda a pain and the calibration LED never lights up (probably DOA) but so far it's been very accurate and fast. I have also used the AEM EUGO and it's a breeze to install, and pretty accurate. I've had others say Tech Edge WBs are awesome too. Hope this helped.
- Garrett
I don't like the AEM    on my Snowmobile, I use the Dynojet Wb2, compare to the Wideband Commander, the WB2 is accurate, and very easy to install    the price is nearly the same as the AEM    On my personnal car (S2000) I have a LC-1 with a display, and this is not easy to wired
									eCtune Team  eCtune Authorized Tuner  Location: Riviere-du-Loup, Quebec, Canada    www.precisionautocanada.com
				sgtmillhouse648
- Garrett
wow that's clean
						Where can I buy this kit? Does it use a standard Bosch type 02?sgtmillhouse648 wrote:I'm a sucker for the JAW or NAW from 14point7 if you have many DIY skills... The controller can be mounted in any sort of case, here it is bare:And if you have a DC etc, you can mount the actual display in the OE clock
				buntinboy9
				sgtmillhouse648
This is the JAW 1.041 made by Allen at 14point7.com.  He has come out with a NAW as he calls it which uses the same display, but is a lot smaller of a system.  You will need to make your own wideband cable, but it uses the regular Bosch LSU 4.2 from a VW, part number 17014.    We originally used a first-gen JAW on our motorsports' team's RX7 and well...I got bored and decided to see if it would fit inside my clock, and sure enough it does.  The actual controller is mounted in a box under the dash ontop of the tunnel.  The actual 0-5V output is wired into the ECU as well which runs wideband closedloop from it.    Here's the actual post I made on Team-Integra.net when I first installed it:
						Originally posted by sgtmillhouse648 on Aug/18/09 So I got the JAW in from Alan at 14Point7 and after getting it assembled I'm extremely impressed with the ease of adapting it to the OE clock... The actual assembly of the controller was a piece of cake. Alan sends the unit and all the components in little baggies which are labeld, and the PCB is labeled with where you need to solder the components to.The display assembles the same way:
Now for the fun part...to put it all in the clock. When you pull the clock, there are 4 screws in the back of it. Pull them out and the back plastic piece slides off revealing the clock circuit board which can be simply pulled out. Then center the display board in and attach using some sort of adhesive. I used gorilla super glue
The only modifications needed to the clock case is for a clearance hole to be drilled for the capacitor:
for a cleaner look, the clock buttons can simply be super glued in from the back leaving this:
Then plug in the 5 pin cable which you construct with the kit and put the back on:
You can see the capacitor protruding slightly from the back of the cover... Everything all hooked up to test:
And a closeup of the new 'clock'
So far I'm defiitely pumped with how easy it has been. I've got to get a case to mount the controller in and then construct a cable to go from the 02 sensor to it. Alan has a link to the connector needed to directly plug into the LSU 4.2 sensor. After that i'll calibrate the controller, and finish the install!
- Civic VTI-Turbo
