Meth Injection?
Natural Aspirations
Meth Injection?
Anyone have any experience tuning a methanol injection system? I have an AEM progressive kit will be using the 550cc nozzle on a JRSC @9 PSI. Hope to have it rough tuned and work out the bugs before I have it tuned.
Natural Aspirations
Re: Meth Injection
This post is out of place.....Coodiagor wrote:I have been saying the same kind of things since day one. I dont think its your meth talking either. I know of a few others here that feel the same but for some reason dont speak up about it. He has 300 posts in a very short space of time, he constantly breaks fourm rules and is never called up about it maybe a few times, and he has an unhealthy interest in the fourm to the point of obsession and people are starting to lay off him for his actions. I for one will not lay off him and I hope others will do the same. He is not who he seems. You have been warned rorta.
Jared... you´re rambling
I have set up a couple of cars (including my own) with the Snow water/meth kit from Xenocron. It seemed to work pretty well. Just get the cheapest one, as you don´t need the fancy controller anyway. They all use the same pump as most other manufacturers. Make the ECU activate the pump through a relay on a GPO. Set the activation RPM a bit low as you need to allow for the pump to build up pressure. For example, activation above 1300mbar, 5000rpm. With the boost you´re running, this would be my suggestion - nothing more advances is needed, really. And yes make sure you start small with the nozzles. /Allan
