Okey, so I'm kind of a noob when it comes to tuning. I mean, I've read alot about it on the web, most of it I understand, some of it I dont. So this winter I installed a t3 .42/.48 on my stock d16z6. I used the shiny program for a while, and took it to a local tuner. He retarded the shit out of it, and I ended up having 6 degrees less timing at peak rpm than the most conservative tune I found at the web (10 degrees @ 11psi). I took it to the circuit track for some fun, and two times in a row my exhaust manifold cracked (not the welds, but the pipe itself, 2mm mild steel). So my guess is that my egt's where up there.     So last month I decided I want to try this myself, bought eCtune and made a DIY detcan. I'm not looking for squeezing every last whp out of my engine, I just want something thats not blowing up because of detonation, but at the same time doesnt melt my exhaust valves or manifold. I also want to learn something out of it, so I dont have to hand it over to a tuner to be safe everytime I change a piece of the setup.    So I made a basemap with flat curves like someone in here was talking about and 1 degrees retard per psi. I'm aiming for 11'ish afr in boost. I made some pulls today, and got the afr pretty stable. I can pick up valvetrain noise very clearly in my detcan, and as I accelerate the sound gets kinda louder, but nothing like the rice-dropping-on-tinfoil, or hammer-hitting-the-piston sounds. I havent really heard detonation before, so I'm not really sure what I'm listening for either :/    So on the last pull today I turned the ignition close to 7000 rpm, and the result is in the pictures. I've been using these plugs for a while now so I dont know if its possible to read anything out of them. I also had been idling for like half an hour before I did the pull. The plugs are ngk bkr7e.    #1 plug:
    #3 plug:
    The graph and my high ignition map:
    Are they supposed to look like this or is this detonation?? I have seen traces of those small particles on my plugs for a long time, also when I was on my crome tune, but when I look at it through the macro mode, it looks kinda nasty... Help anyone?
