question about cams..
timing; -intake: 37BTDC - 49 ABDC -exhaust: 61BBDC - 21 ATDC duration; -intake: 306degrees -exhaust: 302degrees valve lift; -intake: 12.3mm -exhaust: 11.8mm how would these cams work with boost ? owner originally planed a n/a build but now wants to turbo it.
That seems like a Lot of Duration to me for some reason. What cams are these? Something custom?
I just tuned a set of BC 3's on Thursday...I cant believe they have that much duration in them. As far as I know, they are a nice in-between of Skunk2 Tuner 1s and 2s. Held torque flat as a board all the way to 9k on a pretty mild NA setup. I'm sure they would work fine boosted.
It really depends on the turbo setup if those will work or not, run a small turbo and a log, and they will be horrible, BUT run a topumount with a larger turbo and they'll be fine. From the testing i've done, anything bigger than a type R cam on a log manifold won't work well.
