Page 1 of 2
EBC on internal wastegate?
Posted: Fri Aug 01, 2008 8:09 am
by confUsed
Anyone tried running the ebc in ectune on an internally gated setup? I dont have any experience with ebc's, so I dont even know if its possible. But if it might work it would be fun to try
Posted: Fri Aug 01, 2008 10:15 am
by Civic Tsi
Yeah it works.
Posted: Fri Aug 01, 2008 1:08 pm
yup, done it here too, I actually took a guys profec B off, and used the selenoid ..
Posted: Sat Aug 02, 2008 9:55 am
by confUsed
OK, thanks! I'll soon have a new toy to play with
Posted: Sat Aug 02, 2008 1:39 pm
by combz
can someone post a quick diagram (in ms paint) or even a picture of how they actually routed the vaccuum lines to the EBC solenoid to the internal wastegate nipple?>
Posted: Sat Aug 02, 2008 6:46 pm
put the WG inline, between the WG and turbo... so it bleeds off pressure to air when EBC is doing it's adjustment...
Posted: Tue Aug 05, 2008 4:10 am
by FACETUNED
its simple if you take the solenoid and run the vacuum lines from the #2 port to the wastegate actuator and then the #3 to the pressure side or the turbine and filter the #1 then run your ground and then your power to the ecu. Thats it. Good Luck.[/img]
Posted: Tue Oct 14, 2008 12:17 pm
by mafdark
JaredKaragen wrote:put the WG inline, between the WG and turbo... so it bleeds off pressure to air when EBC is doing it's adjustment...
doesnt that effectively create a boost leak?
Posted: Tue Oct 14, 2008 6:06 pm
you can either bleed off or block pressure going to the wg
Posted: Wed Oct 15, 2008 4:42 am
by HiProfile
I think it would be set up as a normally open solenoid (fails to low boost), and 100% DC would be unlimited (full) boost. You wouldn't 'leak' any move CFM's of air through the vent than you would with a normal extranal WG; you'd plug the solenoid's vent since [most] stock actuators slowly bleed off boost all by themselves. Just be aware that the max 'multiplier' over spring pressure won't be as high as being able to pressurize the other side of the WG [external setup]. You could rig it to be dual-ported, but a typical single-port actuator leaks BADLY around the bottom shaft seal. You can get aftermarket actuators that are dual-ported, and seal around the bottom shaft. You would be able to run more boost with the actuator in that case vs just a single port setup.
Posted: Wed Oct 15, 2008 9:44 am
i did a lot of research on wastegate etc etc.. esp now with the synapse i have... wastegate either internal or external require x amount of pressure to open. this is determent by the spring. the spring will allow a x mm lift per psi.. the psi comes from 2 places... bottom port and manifold(backpressure). synapse has the option to adjust initial valve lift too... on some wg the gate starts to open as soon as it see a few psi due to back pressure.. synapse you can adjust when it starts to open. i'm testing 2 thing shortly... bleeding the bottom port and adding it to the top port. 100% dc will give no boost source to bottom port and 100% boost on top port... and CO2 boost controller
Posted: Fri Oct 17, 2008 9:49 pm
by HiProfile
Calvin I've seen some 4-way solenoid valves that could make the 'bleeding' type work, or so I think. It would basicly cycle between pressurizing the top and bottom ports, rather than just adding boost to the top. Most 4-port 4-ways will have one 'input' inlet on the front, the 2nd will be the vent. It will basicly swap the routes between the two outputs. You could then do 100% with the top at boost pressure & bottom at atmosphere pressure, and 0% would be the opposite. I would imagine that you would only have to rewrite some of the input titles to make either work. It would only need different values based on what you want to use, since 100% DC with CO2 could give you far more boost than 100% DC with a normal 3-way boost solenoid.
Posted: Sat Oct 18, 2008 5:51 pm
drop me a mail to discuss this.. what i did now with ectune solenoid is bleed to bottom port to top port... 100% dc is full press on top port and atmosphere pressure on bottom port. Not sure how 4 way work... drop me a mail... i'll try co2 shortly... low boost(low spring) high boost... but is for race application only
Posted: Mon Oct 20, 2008 5:56 pm
by HiProfile
calvin wrote:what i did now with ectune solenoid is bleed to bottom port to top port... 100% dc is full press on top port and atmosphere pressure on bottom port. Not sure how 4 way work... drop me a mail... i'll try co2 shortly... low boost(low spring) high boost... but is for race application only
I think this is similar to the idea in my other thread. The only issue would be releaving the pressure between each cycle/valve movement. I'll send you some pictures I'm thinking of sometime this week, since school has me nailed to the wall till friday. As for the 4-way, most will work by supplying the boost pressure to one outlet, while venting the other; of course, which gets vented is based on the valve being open or closed. I'm sure a 3-way could work fine, except not as cleanly (extra parts?). I'll have to look into that. I think if you got a co2 system working, you'd have a real winner. It seems more and more common for people to put S36x borg-warner turbos on street cars and run 30+ psi at the track.
Posted: Mon Oct 20, 2008 9:08 pm
i guess so
