E85 and Honda engines
- Wazzzup
I did a little research about E85 fuel. But I was wondering if there need to be changes to the fuelsystem or to the engine. Because I read that the fuel is more aggressive than normal fuel.
EG H22A 1/4 mile 13.6 sec @ Drachten with eCtune
I have quite a few cars running around that run on e85 with no problems, many over the 2 year mark now. You do not need to change anything. E85 is NOT aggressive by any means, this is an internet myth that has built up over time as people got confused with straight ethanol and methanol. Even the cheapo 99 cent a foot gas line is rated for e85 use. I believe the SAE standard is j30r7, and this has been met or exceeded by manufacturers for many years. The only time you run into any issue is with raw aluminum it can have a slight reaction, however OEM tanks are steel, lines steel, and the rubber meets spec. Basically, you are fine, just fill up the tank and tune for it.
- Synoptic
you may use less cold plugs, since e85 should burn colder
Yeah, I thought he was talking about compatibility. Injectors and fuel pump are definitely needed for the extra fuel consumption.Civicman86 wrote:Alright, I guess sohcd16y8 is saying everything but those two components will be fine for ethanol use.Bugermass wrote:yes you need larger injectors, and fuel pump.
