Air Compressor Clutch signal (A15): not working
CRXDrew
Post by CRXDrew »
I have been troubleshooting my nonoperating AC compressor clutch. Basically I have come down to the conclusion that the signal from the ECU (pin a15) is non-responsive. (I applied ground straight to the harness which operated the clutch) I have AC enabled and I'm not using the A15 an an output. hmm.... any thoughts?
no clue it should work out of the box.. what about ac cut?
CRXDrew
Post by CRXDrew »
AC cut is not activated. Once I find a minute I'm going to troubleshoot it more... might have a defective ecu. I think i'll see if I can make the pin activate as an GPO. *shrug*
good thinking
HiProfile
Post by HiProfile »
My car doesn't activate the clutch, but I was under the assumption it wouldn't activate if coolant pressure was too low. I've already got the ac pin to activate as a GPO, only thing I could guess is a bad ecu or bad clutch in your case.
