How well does ectune innovate seiral logging work for you?
cbustuner
How well does the innovate serial stream datalogging work for you? Any offset issues or hassles? How is your wiring done for a permanet install with no issues. The reason i ask is i have a zt-2 with display and boost sensor but I'm looking into the neptune tunerview. If i get the tunerview I really don't need two screens with the same information on it.Plus i think I can easily sell the zt-2 for 300 -350+ dollars so that will cover the cost of a new lc-1,leave me a little money left over and give me better readings in ectune.Thoughts? As it is now I have some offset issues with the zt-2.
depends on how good the electrical system is in teh car.. I had a car today that no matter what I could not get serial logging to stay connected for more than a few seconds, and even when I tried to log through the analog input the offset varied so much it was useless. I ended up using the dynos wideband.. But in about 80% of the cars I do it works great.
hmm.. well I know for a fact its an electrical issue, cause if I isolate the LM1 from the car, as in power it from a wall outlet power supply and use a sniffer clamp thats insulated from touching the car, it works perfect.. Mabey whatever noise its picking up from the car is interfearing with the serial stream output. But like I said its only on few cars. This is my 3rd LM1 also, and they have all done the same thing. So its not a bad box. And like today, I did the LS Turbo and I couldn't get it to log for crap so I ended up using the wideband on the dyno, then after that I street tuned another car and it worked perfectly.. In any sence, this is an issue and I think innovate shoulda payed more attention to fixing this problem.
In the beginning I had these kinds of problems also. Then I changed the cigaret lighter plug for 2 clamps to connect the battery directly I never had any problems. By doing this like this I found out that A LOT of cars have bad battery connectors. Almost loose cables are a pain in the ass for the Innovate wideband. The slightest voltage fall will cause problems.
- Bindegal
I tried the Innovate serial link for the first time earlier this week. Customer (Pro user) had his own Innovate unit. Huge problems with offset. In this case on an old LM-1. Switched to the serial link and what a difference... But therein lies one of my problems with the Innovate units. As great as the serial link is, it shouldn´t be necessary to obtain the right AFR´s. Easier, yes - necessary, no! I have 0 (zero! No!) offset problems ever with my Tech Edge. Offset is 0 and AFR is always spot-on. Which allows me to do WB closed loop also. Try doing that with the serial connection. Or \"lean protect\" for that matter. /Allan
- Garrett
On a friend car, I have the same problem as Bugermass talk, and I use 2 clamps connect the the batteryGaskleppie wrote:In the beginning I had these kinds of problems also. Then I changed the cigaret lighter plug for 2 clamps to connect the battery directly I never had any problems. By doing this like this I found out that A LOT of cars have bad battery connectors. Almost loose cables are a pain in the ass for the Innovate wideband. The slightest voltage fall will cause problems.
if this is the case I might as well keep what i have because it doesn't sound like the serial stream will be that much better.Bugermass wrote:I never had offset issues with my old MOTEC PLM.. No matter what car, even if the battery was getting low it still worked perfectly. You get what you pay for..
