CYL sensor error question
I have a problem with a race car. Its an old CRX which is completely setup for track racing.  Its rewired for obd1 and it is running fine besides this annoying CYL sensor error. When I start the engine it gives no error but when I press the throttle a bit it always gives CYL error.     We rewired this car completely so almost half of the loom is left. Al the other cables for lighting etc are gone. So maybe we made a mistake somewhere.   Does anybody have a clue?  Its happening with 2 different dizzy's and with 2 different ecu's.    What did I do wrong?  Are the dizzy sensors +/- sensitive?
									Regards,  eCtune Team   eCtune Authorized Tuner  Location: The Netherlands
I can't recall, but I think that's the sensor the dpfi cars lack. My experience is that sensor is very sensitve to interference. Someone said the stock wires for it come with a foil sheild in the insulation, and ideally it should be grounded. I had to use 16ga wire twisted the whole length in 3 different setups in order to keep that sensor from causing errors.
frank don't forget to use shielded wires for the dizzy sensor(they should be grounded)...  check if the correct sensor come to the correct pins..  use dizzy diagram and ecu pin out...  could be the shielded stuff... contact randy rstech...
									Regards,  eCtune Team  eCtune Authorized Tuner  Location: Caribbean & Suriname    aim:calvinPGMFI  skype:ectune    We remote connect to your laptop if you have problems. Best support in the world.
more than liley the white wires are swapped around  if its a factory dizzy  OBD0 OBD1  orange/ orange  white/ white  orange-blue /orange-blue  white-blue /white-blue  blue-green/ blue-green  blue-yellow/ blue-yellow  large white yellow/green <only color that is different  black-yellow/ black-yellow   blue/ blue    or    OBD0......OBD1  ------------------  [b10].......[b11] --> cyp P aka cylinder position  [b12].......[b12] --> cyp M aka cylinder position  [c3].........[b13] --> tdc P aka top dead center  [c4].........[b14] --> tdc M aka top dead center  [c1].........[b15] --> ckp P aka crank position  [c2].........[b16] --> ckp M aka crank position  [b15].......[a21] --> Ignitor signal
									Regards,  eCtune Team eCtune Authorized Tuner  Location: Port St Lucie, Fl,
i had the same dizzy connect something was missing in it and that cause problems... but shielded wires for sensor is important
