Page 1 of 2
				Borg S362, a/c, p.s., and air filter all in one car...
				Posted: Fri Oct 24, 2008 7:26 am
				by butch11a
				Posted: Fri Oct 24, 2008 8:42 am
				get a good radiator and remove those spoon wires
				Posted: Fri Oct 24, 2008 8:53 am
				by butch11a
				i would if it were my car, i had lots of problems before with aftermarket wires, eventually ended up with new oem wires....tried those with higher and lower resistances, always ended up with high rpm, high boost misfires, installed oem and everything's ok.....
				Posted: Fri Oct 24, 2008 10:01 am
				by Civic Tsi
				Where's the rad for the a/c ?
				Posted: Fri Oct 24, 2008 12:19 pm
				by elevation
				I wonder how hot #3 is going to get that compressor? That is one big turbo!    You gotta get them to use eCtune
				Posted: Fri Oct 24, 2008 5:24 pm
				by butch11a
				we changed the a/c condenser with that of an accord so that the hoses would be at both ends instead of in the middle like the half width condensers...and it makes the a/c even cooler...  they'll probably consider ectune once they find out that their just spinning their tires in the low gears, i told them they'll need a gear dependent boost contol like what i'm working on in my own car...i only have a t3/to4 on my b18c5 and i spin the tires up to 3rd gear which makes the upper rev range useless..
				Posted: Wed Oct 29, 2008 2:03 am
				by HiProfile
				With a cast iron runner next to the compressor, mine was under 300F after a few beat runs - keep in mind the turbo outlet temps alone were over 200F.    As for running a different condensor, excellent idea. I was thinking about doing that in my EG, since the EF has it like that. I just never got any measurements on other cores, and getting the turbo kit/exhaust finished took priority. I took the easy way out and just removed P/S...but not with such a BIG turbo.    Anyone can rip AC/PS out and toss in a huge turbo. It takes real skill to leave it in the Honda.
				Posted: Thu Nov 06, 2008 12:50 pm
				by TopMountGSR
				any pics of the fab work? any pics of the manifold?
				Posted: Mon Feb 02, 2009 3:14 am
				by ACTION JACTION
				I saw these pics on Honda tech.  I like it.
				Posted: Mon Feb 02, 2009 7:57 am
				by butch11a
				Here's last month's build
http://www.honda-tech.com/showthread.php?t=2488711  k20/k24 s368 with a/c...  our current build is a k20, gt35, air water i.c, rear wheel drive in a toyota mrs....
				Posted: Tue Feb 03, 2009 12:31 am
				by HiProfile
				Too bad there isn't eCtune for k-series...*hint hint Calvin*
				Posted: Wed Feb 04, 2009 1:20 am
				by butch11a
				here's another k20, a toyota honda hybrid... and its rwd.
				Posted: Wed Feb 04, 2009 8:15 am
				by SOHCitTOem
				God damn. You got fab skills man. Really impressive. How's the fit of that k20 in the mr-s? Did you have to cut and weld a lot?
				Posted: Tue Feb 17, 2009 11:14 am
				by ef92b
				very impressive kuya Luis!
     mad fab skills!
				Posted: Tue Feb 17, 2009 10:52 pm
				by Piv
     Good job !
