Water injection makes rust on the throtte body
Posted: Thu Nov 06, 2008 5:20 pm
by utkuselamoglu
I have aem water injection kit. We are using this kit almost 3 -4 months. we are having problem with the throttle body because of the rust inside of it. This is our second throttle body but again the same thing occured. The nozzle is located before the throttle body. Normally it is a suggested place the install it. What could be the possible reasons for this issue. Where did you installed the nozzle in your engines. I am thinking that the instalaltion of the throttle body maybe wrong because we are using honda edelbrock victor racing throttle body in my firends european race car citroen saxo not a honda based car... the first throttle body was BDL industries...
Posted: Thu Nov 06, 2008 7:26 pm
by xenocron
Where is it rusting? I have had my Snow Perf kit on for over a year now and I havent had any rust issues.
Posted: Thu Nov 06, 2008 7:47 pm
by utkuselamoglu
xenocron wrote:Where is it rusting? I have had my Snow Perf kit on for over a year now and I havent had any rust issues.
It is on the butterfly pin close to the walls. Sometimes it is being locked and stays open although the gas pedal is removed from the floor. Could it be because of the water injection kit because in aem's kit there is no valve control like other marks. I am thinking that while in the idle engine vacuums the water all the time... normally the control unit stars the pump after 10 psi of boost pressure. I am really confused....
Posted: Thu Nov 06, 2008 8:37 pm
If its before the throttle body its not likely that its pulling water due to vaccum.. another possibility is that its siphoning.. Are you running straight water? or water/meth?
Posted: Thu Nov 06, 2008 9:03 pm
by utkuselamoglu
Bugermass wrote:If its before the throttle body its not likely that its pulling water due to vaccum.. another possibility is that its siphoning.. Are you running straight water? or water/meth?
I was thinking like that. I have tried this also on the manifold the liquid in the tank finishes very quickly. Our mix is like this: %65 water - % 35 methanol
Posted: Fri Nov 07, 2008 12:12 pm
by Bindegal
Suggestion: Use an output from the ECU to activate the pump only when certain conditions are met. Like load, RPM... /Allan
Posted: Fri Nov 07, 2008 1:34 pm
by utkuselamoglu
Aem has it on control unit based on engine load. Okey we figured out that the problem is not related to the rust its related to the installation...:)))
Posted: Fri Nov 07, 2008 8:11 pm
by Garrett
distilled water? Have you ever try Snow Performance Boost juice?
Posted: Sat Nov 08, 2008 8:42 am
by utkuselamoglu
Generally drinking water not tap water is there any other type water? Boost juice must be better than only water and methanol mix.
Posted: Sat Nov 08, 2008 11:28 am
by xenocron
utkuselamoglu wrote: Boost juice must be better than only water and methanol mix.
I dont think so. It's distilled water, methanol and a color additive that doesnt gum up the system is all. Meth is $2-3 per gallon. Distilled water is like $0.50 a gallon or something and you can get it at the supermarket. I wouldnt use tap water...to many minerals, additives, etc in it.
Posted: Sun Nov 09, 2008 12:42 pm
by HiProfile
One issue I'm sure your having is a general methanal-aluminum reaction. Methanol WILL corrode aluminum, no question. If its pooling at any point, especially afterturning it off, your giving it a free meal. As for water, there is RO (reverse-osmosis) and de-ionized water. Both will taste funny due to virtually ZERO minerals being present in the water. Filtered water will be from 200-1000 parts per million of solids, RO water can usually get to around 5-20, IIRC de-ionized gets it down a little lower.
