Psudo boost compinsation
elevation
This is something I've been thinking of and gathering for. A small inherit gas cylinder forces gas through a regulated line(say @ 4 psi) to a solenoid to the wastegate line, put one ways at proper points and energize via gop in first gear. What do you think? used in conjunction with the 3 step and I think you could get a hell of a launch.
antilag is ok, but it WILL cause your wategate to pop open.. This mean you ahve the potential of leaving the line with the wastegate shutting and trying to redirect the sudden changes in exhuast gas direction. Alot of the PRo guys use CO2 to hold the waste gate shut both during antilag and also while going down the track.. Usually with like a AMS1000 Boost management system..
I understand now. Found a good explanation here, under the \"Co2 Boost Control\" section: http://www.evans-tuning.com/techarticle ... _comp.html Very interesting, never heard of this before.
