Combustion temp question
It's been said that highest combustion temps/egt's will often occur at stoichiometry. If this is typical among all cylinder pressures, I don't know, (maybe someone can elaborate.) If this were true, then why do NoX emissions increase at such a rapid rate leaner than stoichiometry. This is in regard to pump gasoline.
Have any links to where you read that highest combustion temps are at stoich?
I just think it depends on a lot of variables... Compression, timing...etc. And combustion temps and EGTs are two very different things as well obviously.
I thought high combustion temps are a result of a lean running engine. I mean if the engine is running lean it would create a lot of heat and combustion temps would sky rocket and form NoX. My 1990 Nissan D21 truck failed emissions 3 times for high NoX. My neighbor told me to dump some iso heet in the gas tank, he said the alcohol or methanol burns cooler. I put 2 bottles of it and gave it another shot and sure did, passed emissions and it lowered the NoX level.
\"Chemical kinetics show that the formation of NO and other oxides of nitrogen increase very strongly with increasing flame temperature. This would imply that the highest concentration of NOx should be for slightly rich mixtures, those that have the highest flame temperature. However, oxygen is also needed for the formation of NO, so the maximum NO emissions occur just weak of stoichiometric. NOx formation will also be influenced by the flame speed. Lower flame speeds with lean mixtures provide a longer time for NOx to form. Similarly NOx emissions increase with reduced engine speed.\" -\"Introduction to Internal Combustion Engines\" - Stone Some other points made in Stone regarding NOx emissions: -Retarding ignition very effective in reducing NOx -Between 5 and 10% EGR is likely to half NOx emissions -NOx emissions are worst for an equivalence ratio of 0.95 (slightly lean) Some explanation of combustion temps from some class notes: \"Slightly rich mixtures are the most reactive but slightly lean mixtures have a higher \"k\" value (Cp/Cv) and lead to higher compression temperatures. Richening the mixture with excess fuel reduces the temperature and reduces knock.\" If the compression stroke is modelled as isentropic, then the temperature ratio T2/T1 = r^k where r is the compression ratio. Since lean mixtures have a higher k value, they will have a higher temperature before combustion even begins, just from compression. Hope this helped a bit
http://www.autoshop101.com/forms/h55.pdf http://www.autoshop101.com/forms/h56.pdf Take a look at those. They help show what is going on with NOx, HC, and CO in the combustion process. They deal more with AF ratios rather than engine temps though.
-Dustin '98 Honda Civic 1.6t SOHC
