B16 auto tranny setup...
eg6auto
I'm in a wheelchair and I have a B16 auto tranny setup. I have two p30 ecu's. Does Ectune work with my setup like crome?
The TCU controls a few different functions that I dont think would be possible with GPOs, but maybe. The ECU just tells the TCU when to go into lockout right?Gaskleppie wrote:ok, not without a auto control box.... sorry. cant this be made with a few GPO's and creative thinking?
With a B Series or H Series that has an external TCU, I usually recommend to customers to start with an Auto P75 ECU, add VTEC and leave it Auto. This is the only I KNOW has worked on setups. With D-Series, I dont believe there are any options...none of them came with TCUs that I know of.eg6auto wrote:It is a hydraulic controlled trans, so the ECU only controls lock-up solenoids. So the program will work, right? Which one to buy?
fuel pump ?
Hello gents, I've had a Walbro 255 in the hatch since the swap. I've been getting poor fuel mileage. Would it be best if I put a stock fuel pump in, and retune until I'm boost'n?
Re: fuel pump ?
The pump shouldnt be a problem...if it is, you would be better off putting an adjustable regulator and fuel pressure gauge on the rail and bringing it down to 41 psi.eg6auto wrote:Hello gents, I've had a Walbro 255 in the hatch since the swap. I've been getting poor fuel mileage. Would it be best if I put a stock fuel pump in, and retune until I'm boost'n?
You have something else wrong then...
