Plenum Structure
Posted: Wed Dec 17, 2008 7:59 am
by PortWerks
I'm designing a custom intake manifold and ran into a dead end. I plan on running individual throttle bodies encased in a plenum to run on a turbocharged application. I understand that the job of ITB's are to push in an equal and maximum amount of air into each cylinder, however how do I know what size to make my plenum to get max. efficiency out of the throttle bodies? I would assume you just need to find the volume of each cylinder and multiply it by 4.. it sounds logical on paper, what do you guys think?
Posted: Sat Dec 20, 2008 4:58 am
by PortWerks
alrighty, so I looked a little bit more into it and I guess in most applications, the most efficient plenum size is the volume of all 4 runners multiplied by 2.5 for a plenum enclosed ITB setup, would this mean the volume from the top of the trumpet to the surface of the head? Do I compensate for gasket thickness?
Posted: Mon Dec 22, 2008 5:43 pm
by butch11a
for turbo itb's i usually go for runner length than volume....for n/a usually 2 to 3 times displacement, depends really on the space available in the engine bay.... here'ssomething i made sometime ago... http://img181.imageshack.us/img181/1056 ... ka6.th.jpg
