Relation between injection timing/fuel value raw
- Piv
Hi everyone, I was wondering what was the relation between the injection timing and the fuel value raw I saw the difference on 2 differents maps on 2 differents software (Smanager/eCtune) for the same basemap (P30UDM) The dutycycle looks differents as well
Would anyone know something about that ? Thanks Romain/Piv
A basemap is just what is says it is... a basemap. Something what would work, but needs adjustment. So you can't compair two basemaps. The two maps will be close matching, but probably won't be exactly the same. It's getting an other story when you're talking about stockmaps. But we're talking basemaps, not stockmaps. I think this is why you see (little) differences. Also take in account that an ECU has (temperature) corrections. If the value in the map is 'low' and the correction is 'high' this would result in the same dutycycle as when the same value in the map is 'high' and the correction is low. so, to much parameters are involved to make a compairison on JUST the map values.
He isnt talking about basemaps...he is asking about injection timing. I have asked Calvin about this a long while ago, but its apparantly buried DEEP in the code somewhere as no one has the ability to play with injection timing. The only thing that MIGHT work to advance or retard the time at which the fuel injector is pulsed is by advancing or retarding the distributor and adjusting the spark timing in the maps accordingly. I havent seen anyone post any results of testing this out with a scope or anything...so I am not sure anyone has gotten in depth with it. My belief is that depending on the setup, there is a lot of power available by being able to play with the fuel injection timing.
I have played with it once. I changed the dizzy and corrected the timing on the complete maps. This way only the injection start time was changed. Funny thing was that I managed to get some extra horses out at lower revs. At high revs it didnt do much. I forgot if I retarded or if I advanced the dizzy. If you are tuning for drivability it could be worth to try.I havent seen anyone post any results of testing this out with a scope or anything...so I am not sure anyone has gotten in depth with it.
I don't think he talking about what either one of you guys are talking about lol.. I think what he means, is the RAW table values.. The raw injection table values are arbitrary numbers that the ECu uses, they will be different between eCtune Smanager and Crome because each of these different softwares calculates fueling differently.. So you can't just copy those values from S300 to eCtune or crome, they don't translate.
- Piv
You're right BugermassBugermass wrote:I don't think he talking about what either one of you guys are talking about lol.. I think what he means, is the RAW table values.. The raw injection table values are arbitrary numbers that the ECu uses, they will be different between eCtune Smanager and Crome because each of these different softwares calculates fueling differently.. So you can't just copy those values from S300 to eCtune or crome, they don't translate.
Dont forget TurboEdit, I always like how he used actual Pulsewidth values in the fuel tablescalvin wrote:all software are different. I beleive everybody does things different. Crome, eCtune, Neptune, S300
