Help turbo opinion
Hawkturbo
Help turbo opinion
Post by Hawkturbo »
hello i have a GT32 garrett Turbo and want too now hoow much power can get fron this turbo the setup is a p72 ITR spring and retainers ITR cams ITM Victor x Trotel BBK 70mm precision 880cc injector AEM fuel ral and aeromotive fuel regulator A1000 Block B18A stock sleeves moroso oil pan Golden eagle vtec kit ACL bearings ITR oil pump Water pump p72 compresor HOUSING Wh Dia Trim A/R Ind Exd 51.2mm 71.0mm 52 0.50 Turbine HOUSING Wh Dia Trim A/R 64.0mm 73 0.69
