fjo injector driver
nce
fjo injector driver
Post by nce »
I switched from using a resistor box to an fjo injector driver, and my afr's went way rich, is this something normal because of the opening faster. Ive triple checked my wiring and nothing else with the car has changed. any input would be much appreciated thanks
battery offsets will be considerably different. correct guys?
nce
Post by nce »
I was thinking that also, so should i leave the multiplier and offsets the same and adjust the batt offsets? I lowered the injector offset alot and it was still wayyyyyyy too rich, and here i was trying to get precision 1000's to idle nicely without being rich
my assumption is battery offsets and your fuyel mapping will change slightly.... probably not too much overall... but that driver definitely changes the way the injectors work.
rschoener
Post by rschoener »
Battery Offsetts Yes.
nce
Post by nce »
it is amazing the difference in using a true peak and hold driver over a resistor box , throttle response has increased big time nice clean idle . I ended up having to change the batt offsets alot but it worked out great thank you for the replys
Adam Hopkins
Post by Adam Hopkins »
If you dont mind me asking how much was it and where did you get it from.
nce
Post by nce »
Its the new version way less wires I got it from xenocron for $150
