How long time on a Dyno
- Piv
I was wondering, once the car is strapped on the dyno and everything ready, how long time do you take to remap a car with a basemap working already Not just at full throttle but every load and every RPM
- Synoptic
between 1.5 and 6 hours.
- Garrett
with all ignition and cam gears ajustement ?Bugermass wrote:now if its a built motor car that the customer wants to max out on pump gas/race gas then it could take 45 mins or it could take hours depending on the setup and what ends up maxing out first.
- Piv
Ok so what do you think if the \"best tuners\" in England take 4-6hours to remap a K20 standard internals just with I/E mods I was just wondering myself if I should take more than 2hours to remap a K20 on purpose just because its the way to do mapping over here in England
Its really start to irritate me
- Garrett
tuning K serie is like tuning a B series with cam gears, it's test and try setting to make the best powercurve it's longPiv wrote:Ok so what do you think if the "best tuners" in England take 4-6hours to remap a K20 standard internals just with I/E mods I was just wondering myself if I should take more than 2hours to remap a K20 on purpose just because its the way to do mapping over here in EnglandIts really start to irritate me
- Piv
It will be nearly the same everytime if you dont change you internals You take a B-series standard internals with cam gears and you will see it doesnt take 4hours to set them as you know where you have to go and an intake and an exhaust will not change everything, it still the same cams and the cam timing from manufacture is damn good already I'm maybe wrong but that what I've seen always make good power at 50deg advance and retard between 20-30 at the redline for a standard K-series Different exhaust, different intake and always the same facts If anyone has another experience ?
- Synoptic
tuning a very complicated built K can take up to 6 hours. a stock K20 + k-pro with bolt ons, should take about 2 hours or less since the basemap from hondata is already good.
- Piv
Ok
Thanks
