What do you think about SM-AFR + DM-5
b20beast
Is the PLX SM-AFR + DM-5 Wideband good? could this do Serial Logging like LC1?
CAN YOU PLEASE DO SOME RESEARCH BEFORE YOU ASK THESE KINDS OF QUESTIONS????? CAN YOU SELECT D14 IN THE WIDEBAND SETTINGS MENU?? YES!! CAN YOU SELECT PLX IN THE WIDEBAND SETTINGS MENU?? YES!! Fucking hell, is that that hard to find???......... If you keep on questioning these kind of questions before trying or researching, ill kick you from the forum!b20beast wrote:Can ectune read 0-5V Wideband on D14 from PLX?
hey no need to get on emotional. i did research. I do not have the plx in my hand at the moment, so i am 'researching'. I know with cr*me you cannot read 0-5V on the honda ecu/input. I was wondering if i needed to rescale my wideband voltages like the lc1.
Gaskleppie wrote:CAN YOU PLEASE DO SOME RESEARCH BEFORE YOU ASK THESE KINDS OF QUESTIONS????? CAN YOU SELECT D14 IN THE WIDEBAND SETTINGS MENU?? YES!! CAN YOU SELECT PLX IN THE WIDEBAND SETTINGS MENU?? YES!! f*** hell, is that that hard to find???......... If you keep on questioning these kind of questions before trying or researching, ill kick you from the forum!b20beast wrote:Can ectune read 0-5V Wideband on D14 from PLX?
but with CROME you CAN use a 0-5v input for wideband.... if you do the o2 0-5v mod, and scale it accordingly in CROME... it works fine. I am trying not to fuel any fires, but people get jumpy on simple things that could easily be found in the logger (free) version.... or on the website/help file. I myself get the same way with things, but it normally takes alot of ignorance for me to get there =)b20beast wrote:hey no need to get on emotional. i did research. I do not have the plx in my hand at the moment, so i am 'researching'. I know with cr*me you cannot read 0-5V on the honda ecu/input. I was wondering if i needed to rescale my wideband voltages like the lc1.
