# Honda Performance Fuel Injector Set 440cc / High Impedance # These performance injectors are perfect for providing the required fuel for your turbo / supercharger or high horsepower project. They are a direct drop-in replacement for your factory Honda injectors. They are flow rated at 440cc/min at 38PSI, and can supply enough fuel to support in the neighborhood of 300WHp. # When used in high impedance OBD0 applications or any OBD1 Honda vehicles, no modifications to the wiring is needed. All new seals included. OBD2 vehicles will require replacement connectors.
Tunertoys 440cc
- Wazzzup
Tunertoys 440cc
which bat offset do I need to select when I want to run Tunertoys 440cc injectors. Info from Tunertoys website:
EG H22A 1/4 mile 13.6 sec @ Drachten with eCtune
I'm not real big on Tuner Toys anything. I think they permanently belong on HMT. I bought a set of their rods for a customer once and the rod bearing tangs were machined in the wrong spot so the top and bottom rod bearings offset each other by at least an 1/8th of an inch. Tuner Toys admitted that they were their rods but wouldn't refund my money, exchange them or help me what so ever. I sure as hell wouldn't trust some re badged knock off injector of 'theirs'.
The injectors are from Keihin. Are they special made by keihin or are they modified by Tuner Toys? The price I payed is about 130 USD. I going to ultrasone cleaning them and than I going to check the flow of the injectors. But the question is how do I control them with eCtune?
