Page 1 of 2
which turbo for streetable B16 civic
Posted: Wed May 13, 2009 3:36 pm
by EITCP
please advise me some good streetable (with journal bearings) turbo for b16 civic. i am wondering would be T3 super 60 the real deal? garrett if possible and no ball bearing ones. I am looking for something with similar results like TD05-18G which is in greddy turbo kits.
Posted: Wed May 13, 2009 3:52 pm
by thething96
gt28rs aka \"disco potatoe\"?
Posted: Wed May 13, 2009 8:52 pm
agreed, 28rs is a killer turbo if you want fast spool and max of about 300HP
Posted: Thu May 14, 2009 1:54 am
by EITCP
but it's a ball bearing one
Posted: Thu May 14, 2009 7:13 pm
by butch11a
borg warner s256 or s258, i have a b18 with an s259, spools earlier than a .63 a/r t3/t4 i had before and they look real nice.....try looking for my old posts for pics....btw they have a different spooling sound compared to garret's...
Posted: Thu May 28, 2009 8:18 pm
by turbo4life
Posted: Fri May 29, 2009 5:27 am
by Bindegal
One of my all-time favourite builds is a simple setup with a bone stock engine and a tiny GT2554 turbo bolted on. For a street (or circuit racing) car this gives you 230HP @ 6-7 PSI and instant spool in any gear. Feels much stronger than the measly horsepower figure indicates. I do realise this is a ball bearing turbo but thought I´d mention it anyway. One of my customers has used this setup for 50K km on a standard B16 which had done 300K km at the time of the turbo install. Only then (and after a number of laps on Nürburgring) did the engine give up. I have a hunch it would last forever on an engine with less km´s on it. /Allan
Posted: Fri May 29, 2009 6:21 am
by Orthello
Bindegal wrote:One of my all-time favourite builds is a simple setup with a bone stock engine and a tiny GT2554 turbo bolted on. For a street (or circuit racing) car this gives you 230HP @ 6-7 PSI and instant spool in any gear. Feels much stronger than the measly horsepower figure indicates.
More people having experience with a GT2554 a stock B16? Because it sounds very enteresting! I'm want a mild setup. So low boost, not to much hp. 225 and 6psi was what I was thinking of. I was looking for T3/T4 or GT28 setups. But this little fellow sounds like it exactly meets my requirements. I don't want to push it to much as it also is my daily driver, which gives me about 100km of fun every day.
Posted: Fri May 29, 2009 6:31 am
by Bindegal
in my opinion, for that mild 6-7psi setup you don´t need anything bigger than the gt2554. And it´s fast enough on a circuit to give some of the higher horsepower cars something to think about becasue its driveability and throttle response is NA-like. This works 259% better than the JRSC setups I have worked with also. If tuned correctly and driver doesen´t have a constant lead foot, mileage is about the same as the standard car. You could probably tune it for better-than-stock mileage with a bit of work
/Allan
Posted: Fri May 29, 2009 7:11 am
by Orthello
TEMPTING
Posted: Fri May 29, 2009 11:33 am
by Bindegal
This is a recent dyno run. 200-220 Nm from 3400 until limiter. Naturally this is not a quartermile beast, but for other purposes quite ideal
/Allan
Posted: Fri May 29, 2009 2:35 pm
I am working on my own engine right now. Its a mildly build B16 with typeR cams, 10:1cr and a GT28RS. Yesterday I started the engine for the first time but its still NA. Now that it runs fine it will be boosted pretty soon.
Posted: Fri May 29, 2009 4:53 pm
by Orthello
I've read the flow map and did some calculations based on my engine @ 6psi. I have my doubts about the high RPM range at low boost (less then 9psi) Can it keep up with the air flow above the 7k RPM? flow map and torque graph both show a decrease of efficiency. But on the other hand, we're talking a daily driver here, so 7K+ is not that important. And the torque graph still show 200+Nm. hmmm.... dilemma!!1
Posted: Sun Jun 07, 2009 6:41 pm
by ls_dx
Gaskleppie wrote:I am working on my own engine right now. Its a mildly build B16 with typeR cams, 10:1cr and a GT28RS. Yesterday I started the engine for the first time but its still NA. Now that it runs fine it will be boosted pretty soon.
that should be a really fun driver!!
Posted: Tue Jun 09, 2009 9:23 am
by TopMountGSR
that little 28 is a bad bitch.. I tuned a 240sx, stock sr20 swap, cams and bolt ons w a gt28r on it and it went 11.0 in the 1/4 mile. 1.55 60ft You pop the hood and in my eyes looks no different from the stock one. It just amazed me. This car was getting ten kinds of nasty street tuning it on 26\" slicks and welded diff.
