Posts: 251 http://phpbb3styles.net
Post
by ckretvix » Sat Jun 06, 2009 8:19 pm
Trying to figure out why my car wont start. Fuel pump works and Im pretty sure ignition is fine. My wideband shows no fuel getting through the engine when I try to start it (Stays lean), so injectors arent fireing I assume. What could cause this? The only thing I was doing before hand was playing with the key on/off and disconnecting the battery trying to figure out the EBC.
IHaveTurbos
<font color=red>eCtune Authorized Dealer</font><br><font color=green>eCtune Authorized Tuner</font>
Posts: 41 Joined: Thu Feb 19, 2009 5:07 am
Post
by IHaveTurbos » Sat Jun 06, 2009 8:34 pm
Did you make sure to push the cal to the ostrich?
Posts: 336 Joined: Sat Apr 14, 2007 2:46 am
Post
by Almighty-Si » Sat Jun 06, 2009 8:46 pm
Possible you hit the kill injectors in the drop down menu?
Posts: 251 Joined: Thu Jan 22, 2009 9:29 pm
Post
by ckretvix » Sat Jun 06, 2009 8:49 pm
Almighty-Si wrote: Possible you hit the kill injectors in the drop down menu?
Would that hold true even if I unplugged the battery?
Post
by ckretvix » Sat Jun 06, 2009 8:54 pm
Just checked that and its fine. So is the main relay..
Post
by ckretvix » Sat Jun 06, 2009 9:01 pm
IHaveTurbos wrote: Did you make sure to push the cal to the ostrich?
ostrich is working. can connect to ecu fine.
Post
by ckretvix » Sat Jun 06, 2009 9:38 pm
Problem solved? Car starts and runs fine now. All I did was unplug and replug the injector clips back on and touched a bunch of wires....
elevation
Posts: 195 Joined: Tue Apr 10, 2007 10:24 am
Post
by elevation » Sat Jun 06, 2009 10:30 pm
eeerrrr...
