Rebuilt USDM Type R, and still smoking.......
Hi, a friend recently rebuilt a US 2000 Type R engine. Got new piston rings, bearings, head gasket, new valve stem seals, head studs, rod and main bolts, new pcv valve, and misc. gaskets. The car would burn oil and smoke, specially at light load and between shifting, so we assumed it needed to be rebuilt. But after all the work, the engines still burns the same amount of oil, and it's still smoking. I heard that Type R blocks, after many miles(or kilometers!) the cylinder walls tend to \"oval\" out. Any one with similar issues? Thanks............
The thing is, the car was doing exactly the same thing before and after the build. When the car first started to burn oil, the guy assumed it was a bad head gasket. He replaced that, but didn't do anything. After that, he then replaced all the other parts, but it's still pretty much the same. I figured that I wasn't the only one to know these kind of issues, but I have no clue what else could be wrong.......
- g.t engineering
re
if you didnt replace the valve stem guides, the valve stem seals were pointless to replace. was the head redone at a machine shop or did the guy just replace the seals? if the guides are worn out and letting the stems walk around the seals are already destroyed. here are the specs.
- valve guide spec
- type r valve guide service spec.JPG (28.74 KiB) Viewed 4560 times
