Relay clicking
civic4g
Relay clicking
Post by civic4g »
Hi Sometimes I notice that a few minutes (2 or 3) after i've started the car, I hear a relay clicking a few times and the engine stalls if the car is stopped and idling. If this happens when i'm already moving/cruising the engine will stall and recover. Any clue of what can cause this? Thanks in advance
relic1
Post by relic1 »
have you checked, replaced or repaired the main relay?
civic4g
Post by civic4g »
relic1 wrote:have you checked, replaced or repaired the main relay?
No, but I don't think the problem is on the relay because this only happens when demon is connected to the laptop. I also loose connectivity to demon when this happens, don't know if it's the lost of connectivity that makes the relay click or vice versa.
I have the same when I connect a tunerview to my ecu which has a normal chip. So its not the demon. I asked the guys from tunerview and the told me it was some kind of distortion in my car. I had to set some caps over the ttl connector in the ecu. Never tried it though... Normaly I dont have the tunerview connected.
utkuselamoglu
Post by utkuselamoglu »
it could be de deamon.... We had the same issue than we have checked that the deamon is not connected to the ECU correcly... there could be a short between the legs..
utku selamoglu
groottAnync
Relay clicking
Post by groottAnync »
im trimg to figure out if ,y fuel relay has gone bad but i cant find it. can someone please help me locate this. my car is not running and i need it bad. i have a 92 ls400. thanks for the help.
MantisX
Post by MantisX »
My car did this when I found my ribbon cable on my ostrich had gone bad. So it could indeed be an issue with whatever connects the demon to the ecu(No clue, dont own a demon) Hope this helps MantisX
