Spark Plugs ?
Spark Plugs ?
Hey guys, What plugs do you recommend for a boosted B16b ? The spec's are : B16B with ITR pistons (9.2:1 c/r), Garrett T3 turbo and i'm aiming for around 300bhp. I'm thinking 8s (R5671a-8 ) at the moment as stock are 7's. Cheers
Hows it going mate ? Nice one for that i shall order them tomorrow then. My setup is comming along fine thanks. I had a bit of trouble at first due to the oil pressure going to the turbo being to high, but i'v got it sorted now. I'm in the stages of mapping it at the moment, but i'm finding it hard to find the time. I only have a couple of hours at the weekend and me been quite a newbie to tuning its going to take a while... CheersVtec6000 wrote:Yeah you should be fine using 8's for your setup mate. How's it coming along btw?
Did the oil manage to push its way past turbo seals with the high pressure? Did you use a oil restrictor on turbo oil feed to solve the problem? Taking your time is the best way to learn and less likely to break anything in the process. Are you putting it on dyno at all for tuning?rich777 wrote:Hows it going mate ? Nice one for that i shall order them tomorrow then. My setup is comming along fine thanks. I had a bit of trouble at first due to the oil pressure going to the turbo being to high, but i'v got it sorted now. I'm in the stages of mapping it at the moment, but i'm finding it hard to find the time. I only have a couple of hours at the weekend and me been quite a newbie to tuning its going to take a while... CheersVtec6000 wrote:Yeah you should be fine using 8's for your setup mate. How's it coming along btw?
You should look into plug reading. Its a valuable tool to have if your going to be tuning. I found this thread to be helpfull http://forum.ectune.com/viewtopic.php?t ... sc&start=0
Yeh thats what happend, it wrecked the oil seal and it needed replacing. The oil was going right into the exhaust housing. I got somewhere over here to replace it with a 360 degrees seal and check it over. Yeh, i'm sure taking my time with itVtec6000 wrote:Did the oil manage to push its way past turbo seals with the high pressure? Did you use a oil restrictor on turbo oil feed to solve the problem? Taking your time is the best way to learn and less likely to break anything in the process. Are you putting it on dyno at all for tuning?rich777 wrote:Hows it going mate ? Nice one for that i shall order them tomorrow then. My setup is comming along fine thanks. I had a bit of trouble at first due to the oil pressure going to the turbo being to high, but i'v got it sorted now. I'm in the stages of mapping it at the moment, but i'm finding it hard to find the time. I only have a couple of hours at the weekend and me been quite a newbie to tuning its going to take a while... CheersVtec6000 wrote:Yeah you should be fine using 8's for your setup mate. How's it coming along btw?
Thanks for that ! theres some great info there...dbsharp wrote:You should look into plug reading. Its a valuable tool to have if your going to be tuning. I found this thread to be helpfull http://forum.ectune.com/viewtopic.php?t ... sc&start=0
