AEM meth kit \"boost safe\" output
jblsvtec
Hi, i have a question i plan on buying a meth kit from aem. There meth kit has a \"boost safe\" output which will trigger a ground signal if it detects a short, loss in continuity from a broken wire or bad connection, blown fuse, overheated pump, overheated pump driver, or a high or low voltage condition and if fluid level begins to get too low. Now my question is is there any way i can set up ectune to use that ground signal as an input to like shut off or disable the ebc solenoid?
