NGK R6601-8 - Has anyone tried?
- Wheelman
- utkuselamoglu
You can use non resistor type v-power spark plugs with ectune. we had no problems. but using an iridium type will be better in your setup. but the main problem could be the radio frequency interference in your car could be more than our cars. You can try installing your ignition box away from your ecu. You should keep those things seperate. otherwise you will have problems.
utku selamoglu
