Running richer after Toda header.
- civic4g
Hello guys I was running an oem header and a few months ago I've decided to buy a Toda header, for my surprise, after install, I was getting richer afr's when I was expecting to get leaner afr's and add fuel as necessary. Where my expectations wrong? Anyone can explain why this happened? Thanks in advance
- utkuselamoglu
Before I had an OEM ITR EDM header (4-2-1 2.25 outlet). I didn't compare the low cam fuel map yet, but in high cam fuel map is requesting less fuel everywhere.rich777 wrote:Strange... I'd imagine if its done your car any good then you should be leaner. What header was on before ? When you say richer, where about is it richer ? i.e low down ? high up ?
