No pulse to fire the injectors?
Ok so some back ground. The cars a EF7 CRX which is a JDM model with a DOHC ZC in OEM form. Mine has a B18c swap using a odb0-odb1 harness using a P30 ECU which will run with my copy of eCtune once it starts....... The harness was a boomslang which didn't work so I made changes using THIS which has worked on many EDM/JDM cars before. After searching around the web I found a few things to check out... The three sensors in the Dizzy TDC/CYL/CRANK & they all test out with the right resistance to be working at the ECU plugs so the wiring/dizzy look to be fine. PGMFI ground issues is a well known cause of weird problems so st's ultra clean & has a separate feed direct from the negative terminal of the battery! There's also grounds from the battery to the chassis leg on clean bare metal to be sure as well as to the gearbox & valve cover. I'm running ITR OEM 240cc injectors for now to get the car running (I have ID1000's for when the turbo goes on after the engines ran in) so I've changed the injector plugs over to the ODB2 plugs & deleted the resistor box. I've checked that the 12v feed is provided by the main relay & that the four injectors are wired back the the right pin on the ECU. After all this I don't get any pulses from the ECU to fire the injectors. If I squirt a bit of fuel past the throttle body the car fires so spark etc is here I also checked the spark & it's strong enough. One weird thing I noticed is if I unplug the EACV the main relay shuts off I think & when you plug it back in the fuel system re primes? So I thought there must be an earth issue as it seems the EACV earth is earthing more than just the sensor! Please help I'm so tired I can't think anymore but I really need the car running now asap! As it looks like I might be loosing my job I need to have this running so I can sell my daily driver to pay my bills maybe
Bill
Correct. You can ohm the pickup, but the signal is the important part and the only way to check it is with an oscilloscope (lab scope)joppez wrote:I did exact same thing, but resistance is about same so you dont know if wiring is right, only that there is somethingThe three sensors in the Dizzy TDC/CYL/CRANK & they all test out with the right resistance to be working at the ECU plugs so the wiring/dizzy look to be fine.
