b series transmission question
sloweghatch
Post by sloweghatch »
Is it possible to install a differential from an ls transmission into a gsr trans. I've got a nice quaiffe differential installed in an ls transmission that has bad gears is it possible to swap it into a fresh gsr trans I just picked up? Any help is appreciated
Natural Aspirations
Post by Natural Aspirations »
The LS diff will work if you swap over the final drive. AKA Ring and Pinion gear
Natural Aspirations wrote:The LS diff will work if you swap over the final drive. AKA Ring and Pinion gear
Pinion being countershaft :)
