Anyone experienced with vtec-e D15z6?
Posted: Sat Sep 29, 2012 4:39 am
by Bindegal
So here´s the plan. Step 1: Buy a VTEC-E econobox EK Civic with D16z6. Done. Step 2: Spend shameful amounts of money fixing it up.(In progress.) Step 3: Break it in for a month or two, unmodified. Step 4: Fit other MAP sensor, injectors, wideband, making a nice base tune and see if comparable-to-stock MPG is possible on eCtune + fancy closed-loop measures. Step 5: Fit a tiny turbo and re-tune for 180 hp + economy. Step 6: Enjoy cheap-ass daily driver with über economy + torque, yeay. Any thoughts, input? Will the D15 break up as I apply a bit of boost to it? Has anyone dabbled in playing with the EGR using boost control settings? I have a hunch that some of the fuel economy comes from EGR on the standard car. Thanks
/Allan
Posted: Sun Sep 30, 2012 4:01 pm
Great plan! You can try to let it run in ultra high AF mode by using wideband closed loop @16:1 or so to get max fuel economy. If you tune the maps with normal AF's, but setting a target closed loop at 16:1 or so, it might work. Maybe you dont even need egr. Even under light boost it must be possible to run 14:1 if you use conservative timing. I heard some stock old turbo volvo's are running closed loop lambda 1 at 5psi.
Posted: Mon Oct 01, 2012 3:47 pm
by relic1
IMO the D16z6 is not the best bet for this idea. VTEC-E available in: D15Z1 - OBD1 VX D16Y5 - OBD2 HX D15B - JDM counterpart to above along with various others around the world. (see the Wikipedia article) what I've dreamed of doing, and will likely never have time/money for... 3-stage D15b with small turbo, tune with P72 for mpg, power and drive-ability.
http://www.b18c5eg.com/VTEC/3stagevtec.html The VTEC-E head design brings the coolant passages closer to the combustion chamber and exhaust ports allowing the higher A/F values while cruising (lean-burn)
Posted: Mon Oct 01, 2012 4:09 pm
by Bindegal
Oh oh there´s no way I would ever own a D16Z6.
D1
5Z6 is the vtec-E found in our euro EK3 models. D15Z1 is the older vtec-e type, lower power. Sourcing bits and parts these days, as my mechanic lets me know which spots on the car is ALSO rusted out, yeah ! I have evil plans of using a GPO to switch to a different (lean lean) output from my Tech Edge wideband and activate lean-cruise when conditions are right. So... normal closed-loop (high cruise?) AFR 14.7, lean-lean cruse: AFR 17 or something. If I don´t blow it up, it could be the perfect eco-cruiser
/Allan
