taking lambda sensor out and putting wideband sensor in
eric o neill
Post by eric o neill »
taking lambda sensor out and putting wideband sensor in for tunning will i need to disable the 02 sensor ?on my b16a
Yes for tuning purpose disable O² sensor heater if you run closed loop on wideband , you need to wire analog output of your WB to ECU wich wideband is it?
eric o neill
not yet order one mybe a innvate lc1 or aem ugo
Innovate have the ability of serial logging so no wiring headaches no voltage offset just remove the stock sensor and disable it in the software
